Author Topic: Removal Of Front Bumper  (Read 1383 times)
Offline adyh
« on: 09 August 2006, 12:40 »
As far as i can see i need to remove the front grill , but where do i go from there ?
Offline carl
Re: Removal Of Front Bumper
« Reply #1 on: 09 August 2006, 13:32 »
on the front inner plastic wings there are 2 plastic gromets on each side that need to be taken out ,under the front grill there are 3 bolts ,where the air vents on the bumper are there are 1 bolt each side ,and under numberplate there is 1 bolt ,
hope this helps carl.
Offline Gray
« Reply #2 on: 11 August 2006, 09:30 »
Do you Know where i can get the two gromets from, that connect the bumper to the arch lining coz i'm missing 2 from each side of the bumper, Cheers
Offline carl
« Reply #3 on: 11 August 2006, 11:26 »
main dealer only mate they are only a few pence.
Offline adyh
« Reply #4 on: 11 August 2006, 11:53 »
Ive had another look , and it appears that all i need to remove is the black rubbery plstaic bit on the top , i reckon i should be able to get this off with the bumper on , is that the case (i just need to replace that bit)
Offline carl
« Reply #5 on: 11 August 2006, 15:03 »
sorry youve lost me  :huh: :huh: :huh:
