Author Topic: No Heat!  (Read 3688 times)
Offline Svenson
No Heat!
« on: 02 March 2003, 21:48 »
I have a 1988 Mk2 Golf gti 8v. I recieve no heat in the car from the fans. I have replaced the thermostat and temp sensor but still no change. The inlet pipe to the radiator gets hot and so does the outlet pipe but no heat seems to get inside the car? Do you reckon the heater matrix has been bypassed? PLEASE HELP cus its really p*^%~*g me off!
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline richandhazel
Re: No Heat!
« Reply #1 on: 03 March 2003, 19:51 »
Airlock.
Try loosening the jubilee clips around the heater hoses where they enter the matrix at the bulkhead. Hopefully you'll find air escapes instead of coolant.
Failing that, there was a thread here a while back that mentioned a valve failing.
« Last Edit: 01 January 1970, 01:00 by -1 »
Re: No Heat!
« Reply #2 on: 03 March 2003, 20:26 »
I found that thread I was on about so here it is repasted again  :)
for your heater problem, pasted this from another thread:
forgot the heater problem, again my golf had this one too...
if you tace the water pipes round the engine you will see two heading off into the bulkhead. Just before they go through the bulkhead (towards the heater matrix) they should both pass through a valve (one valve on each pipe). On the inlet side this valve is metal and on the return side it is plastic, in between the two valves there is also a thermo-controlled bypass for the heater matrix.
All the valves do is control the flow through the matrix to prevent it exploding when the engine is running hot (apparently this was a problem in early golfs and warranted a recall).
Your problem is probly with the metal valve, take it out and test it by running water through it (in the direction of the marked arrows), cold water should run freely through the unit.
If faulty a replacement will be hard to find at a scrap yard, it took me 4 tries, the other three had the same fault.
Good luck
svenson
Re: No Heat!
« Reply #3 on: 03 March 2003, 20:41 »
Cheers buddy ill give it a try! Any other ideas would be helpful!
Re: No Heat!
« Reply #4 on: 06 March 2003, 02:30 »
Have you sorted out your heater? Drop into chat, maybe I can help or point you in the right direction :D
