Author Topic: Dying Mk3  (Read 1037 times)
Offline toddy98274
Dying Mk3
« on: 08 August 2006, 21:26 »
I have a Mk3 golf gti 8v engine code AGG which has done 133k miles and is in need of serious attention.
It has had a very rough idle for a while now, plus has had the stalling issues that appear in a lot of other threads.  To solve this I have replaced all the relays, new plugs, leads and cleaned the original throttle body and then finally replaced it completely
However the car still stalls a lot when coming to stop and now it has started to become jumpy if you put your foot down further than half way
By this I mean you can actually see the revs jumping up a few hundred at a time and the car is kangarooing down the road (not a good look!!)
The cam belt is probably over due for replacement but would this be the cause of all these kind of symptoms?
Any suggestions would be appreciated
Offline boneybradley
  • Back in a Mk3...
Re: Dying Mk3
« Reply #1 on: 08 August 2006, 22:17 »
First thing to do is get the fault codes read cleared and see if  any appear again (after a bit of driving), you can get a code reader by draper for about £20 or pay a garage to do it!!!!! Wouldn't say it's the cam belt if this had slipped your motor would be fkd..... :smiley:
