Author Topic: fuel cap switch thingy  (Read 1389 times)
Offline threadders
« on: 07 August 2006, 21:26 »
Hi yall
My fuel cap is busted and will not close properly, I have been told that is a MOT fail as well ?
Also been told its a Charlie Uniform November Tango of a job to fix.
Anyone else has the same prob ?
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: fuel cap switch thingy
« Reply #1 on: 07 August 2006, 23:01 »
I take it you still get the electronic noise when you push the button by the handbrake, but there's just something in the way when your trying to push the flap shut??
If so, then the motor which moves the pin up & down to lock the flap will be foxtrot uniform charlie kilo echo delta.  :wink:
Sorry, can't help with DIY, as my motor was under warranty when it went.  :sad:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GolfGL
« Reply #2 on: 08 August 2006, 21:35 »
Looking at the haynes its only removing some trim and then the motor.  I'd check all your fuses/relays to make sure nothings blown thats causing it not to work firstly.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline threadders
« Reply #3 on: 09 August 2006, 12:53 »
I'm sure the switch does work but its the metal bit on the outside that wony close
