Author Topic: Steering lock  (Read 1462 times)
Offline rzacasperof
Steering lock
« on: 04 August 2006, 20:35 »
Hi all, Quick Q....
Is it possible to fix the steering lock?  It's always been broke on my cab and seeing as i'm on a mission to put everything right on her was wondering if this can be done?
Re: Steering lock
« Reply #1 on: 05 August 2006, 22:09 »
yeah, you need a new ignition switch/lock housing!
You'll also have to drill a small hole in your old one so you can remove the old ignition lock, the haynes has a diagram which shows you exactly where.  Basically the lock has a snall tab you have to press with a screwdriver to release it!
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
Re: Steering lock
« Reply #2 on: 06 August 2006, 16:49 »
Spot on... nice info..
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline rzacasperof
Re: Steering lock
« Reply #3 on: 10 August 2006, 08:18 »
Thanks for the info.  Priced the part up, £23 from local VW dealer.  Gonna give it a whirl next weekend :)
