General discussion
mk 4 turbo
Topic: mk 4 turbo (Read 2301 times)
workhorse '90 8v
Here all the time
mk 4 turbo
23 December 2003, 15:11 »
what bar/psi does the turbo run at on a mk4?
kniterider
Guest
Re:mk 4 turbo
23 December 2003, 15:13 »
not sure will have a gander on uk mk4 site and try to find out for you!!, (im assuming u want standard psi figures??)
workhorse '90 8v
Here all the time
Re:mk 4 turbo
23 December 2003, 15:32 »
standard yes please...
kniterider
Guest
Re:mk 4 turbo
23 December 2003, 15:54 »
0.6 bar/9 psi, so ive been reliably informed!!! hope this helps!!
workhorse '90 8v
Here all the time
Re:mk 4 turbo
23 December 2003, 16:13 »
Thanx.
Very interesting.. I've heard it said that anything below at least 1bar is not gonna give that kick which people come to expect from a turbo charged car.
I don't understand why manufacturers don't crank it up as standard?
They're givin turbos a bad name!?
Last Edit: 23 December 2003, 16:22 by mud splattered 8v
kniterider
Guest
Re:mk 4 turbo
23 December 2003, 16:26 »
yeah i know what your sayin !!!!, ive had many a 'turbo' car i was a full on turbo rush boy in the early 90's!!! loads of lag then a big fookin kick up the arse!!!!, they dont seem to do it like that now!!, smaller turbos and less lag half the time you dont even know youve got a blower on there !!! un less remapped/chipped etc!!!, i always used to run bleed valves and crank em open a bit when i used to get bored!!, and if i had the turbo model golf id do the same!! have got a nice brass bleed valve sat in me shed now!!!,
workhorse '90 8v
Here all the time
Re:mk 4 turbo
Reply #6 on:
23 December 2003, 16:28 »
Thats the spirit!!
General discussion
mk 4 turbo
