Author Topic: Aftermarket xenons  (Read 4080 times)
Offline deva
Aftermarket xenons
« on: 03 August 2006, 21:46 »
Hi,
Has anyone fitted aftermarket xenons to a GTI? Do they work without problems? Is it worth the hassle??
Thanks
Offline The Doc
  • E63s Estate - Vito Sport
Re: Aftermarket xenons
« Reply #1 on: 03 August 2006, 22:36 »
Hi
If you fit 'em you will have two problems:
1. The aftermarket H7 bulb is too long and shorts out on the "VW" metal reflector in the headlamp and cause the balasts to blow prematurely.
2. The dash displays a fault on your headlamp bulbs - this can be overcome with the use of resistors but they get very hot.
The beam pattern is a little out of hugh.
You can fit them into the main beam and from fogs without problem 1.  :wink:
Offline deva
« Reply #2 on: 04 August 2006, 14:24 »
Thanks for the response :smiley: I now think that it is not worth the trouble! My next VW will have standard xenons :wink:
Offline 2007GTI
« Reply #4 on: 14 September 2006, 16:09 »
Doc,
If I buy the secondhand OEM R32 complete xenon headlamps from german ebay, do you know if they will fit without causing any problems?
Just got quoted £220 per headlight for the HID xenon headlamp for a Mk5 from a VW stealer, plus £114 for a bulb!  So £668 all in.
Paul
« Last Edit: 14 September 2006, 16:18 by 2007GTI »
Offline jimbolane
« Reply #5 on: 20 September 2006, 15:02 »
Don't forget, if you have xenons fitted to your car it must also have headlight washers to be road legal and pass MOT.
Offline 2007GTI
« Reply #6 on: 20 September 2006, 16:56 »
looks like I wont be getting them then!
Offline The Doc
« Reply #7 on: 20 September 2006, 17:22 »
"Don't forget, if you have xenons fitted to your car it must also have headlight washers to be road legal and pass MOT"
If this applies you would also need dynamic beam leveling.
BUT I think that all this only applies to manufacturers not if fitted aftermarket  :smiley:
Offline 2007GTI
« Reply #8 on: 20 September 2006, 19:42 »
does that mean the new ones from german ebay arent just plug and play?
