Author Topic: Mk4 Turbo GTi 20v  (Read 1965 times)
Offline Rob GTi
  • Watch out for Chav's
Mk4 Turbo GTi 20v
« on: 23 December 2003, 11:52 »
Has anyone had a problem with a misfiring turbo. Mine went yesterday, hopefully still under warranty. Should it go at 17k.  Any other owners had this problem, and did it cause any other problems to car. Mine is at VW dealer to check problem. :(
'51 Black 1.8T GTi - Totally standard - Except for a GTi badge on the front!!!!
kniterider
Re:Mk4 Turbo GTi 20v
« Reply #1 on: 24 December 2003, 11:42 »
coil packs are a common problem on these 'turbo' 1.8 20v engines!!!, if your under warrenty i guess vw will change these straight away!!!!!let us know how you get on!!! :D
Offline mwal
« Reply #2 on: 15 January 2004, 14:22 »
 Hi, my car is the same 1.8 gti 20 valve turbo, 2001.
  My english is very poor, but if you understand spanish, very well.
  Yo estoy empezando a modificar mi auto y si tu tienes informacion sobre ello podriamos compartirla, mi idea es partir con un overboost greedy que me acaba de llegar desde USA, posteriormente escape, cambiar el turbo, inyectores y el control de inyeccion, seguramente via el apexi AFC u otro similar, si te interesa avisame.
