when i pull up at junctions and lights sometimes my 88 8 valve revs constantly to 2,000 then nearly to 0 then back again. it stops (sometimes) when i switch off lights, heater, or unneeded electrical things wipers etc. but sometimes this is not possible as there is nothing switched on, any ideas what is causing this? its become embarrassing as 'old dear's' run across the road in fear then give me the evils, and mopeds think that i want to race them....as if (they only clog my air filter)
any ideas ?
also i was thinking of removing the straight section (stits under the tunnel)from my exhaust and replacing it with a straight through pipe of larger diameter, would this be detrimental to my engine?, i allready have a Ashley middle and back box off i presume a 16v as the bore diameter is bigger, would noise be the only issue?
