Author Topic: 8v Digi cuts out on full lock  (Read 2527 times)
mix
Re: 8v Digi cuts out on full lock
« Reply #10 on: 04 August 2006, 09:31 »
what wee hands you must have!!
 :lipsrsealed:
« Last Edit: 04 August 2006, 09:34 by Lofty! »
Judderi
« Reply #11 on: 04 August 2006, 14:46 »
PAS you women :laugh:
(at least i don't think i have PAS.... :huh: )
You probably do have it and havent really noticed, its not exactly light.
mix
« Reply #12 on: 04 August 2006, 16:39 »
trust i havent got it, and it not to heavy imo...my bros steering is proper light.......
Offline Neaty
« Reply #13 on: 10 August 2006, 17:54 »
if it only does it when its raining its cos youre getting water on the belt.there should be a black plastic guard that bolts on to the inner wing cover which stops water getting on the belt.check the belt to make sure its not worn or loose.when i did my previouse engine change i never got round to putting the guard back what with all the problems and if rained it was a nightmare the steering would go al stiff and juddery when going round corners maily right hand corners i think cos the belt was taking a direct hit.as thwe wheel turns as youre turning right the water spray of the back of the tyre is fired up into the arch and down onto the belt.
makes sense
it certainly made it interesting when i pulled into a carpark with a wall either side of the enterance and it went all stiff just as i turned in, just managed to go back to normal before i was about to plough a wall down!  :laugh:
my mark 2 power steering is lighter than my dads mark 3, which i thought was odd, must of had a new pump at some point
« Last Edit: 10 August 2006, 17:56 by Neaty »
Veedubgt18v
« Reply #14 on: 11 August 2006, 22:54 »
sumthing must be up with yours then mine is light but still feels connected to the wheels if u know wat i mean?
Offline Neaty
« Reply #15 on: 11 August 2006, 23:02 »
mine too
Offline silkyballs
  • more tea vicker??
« Reply #16 on: 13 August 2006, 00:19 »
im running 16" audi a4 rims and its as light as feather!nice!only cos im lazy!lol
http://[img]
