Author Topic: rough idle  (Read 961 times)
Offline ace
rough idle
« on: 01 August 2006, 13:25 »
hey all, im new to this forum but ive been very impressed with everything.
right basically i have a mk3 gti 8v with the agg engine. ive had the same problem as most i.e. cutting out (last summer). i managed to sort this out by cleanin the throttle body and breather pipes.
however now when i serviced the car a couple of weeks ago im getting very rough idling. the revs drop to around 750-800.
took the car to get it on the computer and it came up with 2 faults
1. air intake sensor
2. engine coolant sensor
i have now changed the 2 parts and had the ecu reset but ive still got the same problem.
does any1 have any ideas what i can try next????
Offline adyh
Re: rough idle
« Reply #1 on: 01 August 2006, 15:50 »
Check your pipes and throttle body again .
Offline ace
Re: rough idle
« Reply #2 on: 01 August 2006, 20:40 »
yeah ive done that about three-four times but nothing.
ive changed the plugs, leads cleaned the dizzy cap and changed the ecu relay but ive still got the problem.....
