Author Topic: How??????  (Read 3575 times)
Offline frog
How??????
« on: 31 July 2006, 13:13 »
Right, i want to remove my drivers seat and fit an aftermarket bucket seat. I've built up the replacement seat and mounting bracket but this is where i am stuck.
The bracket i have doesn't have the feet that sit in the slides, is it possible to remove the mounts/feet off my original seat and use these? I've had a look but cant work out how there fitted and dont want to butcher this seat as if it doesn't work then i'm stuck without any thing to sit on?
Any one else done something like this or any ideas?  :huh: :laugh:
Offline [han]
  • Graphic Designer for Haribo
Re: How??????
« Reply #1 on: 31 July 2006, 13:20 »
dont you need to buy a model specific subframe?  :embarassed: im not too sure..
Offline baz_the_man62
Re: How??????
« Reply #2 on: 31 July 2006, 13:28 »
as far as i know han is right, subframes specific to the car should go strait in.  on the original seat the whole lower half is all 1 peice so cant really take bits off that as the base wont match ur new gear.
Offline frog
Re: How??????
« Reply #3 on: 31 July 2006, 13:33 »
Hi I bought these sub frames but cant work out how the rear fits onto / into the slides
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300000416451
Offline Agreeable Slick
  • Unit
Re: How??????
« Reply #4 on: 31 July 2006, 14:12 »
"PLEASE NOTE PICTURE IS FOR EXAMPLE ONLY" - well there is one problem solved.
if it in the ones in the picture, then they will need to be drill mounted. Fun Fun.
Offline frog
Re: How??????
« Reply #5 on: 31 July 2006, 15:41 »
No its not the ones in the picture there is a middle bit at the front which lines up with the mount but at the back there are 2 legs with holes in them, these i think need to be connected to the existing feet/mounts and then all should fit, but how are the original mounts / feet fitted?
  • Unit
Re: How??????
« Reply #6 on: 31 July 2006, 15:49 »
Picture please.
Offline frog
Re: How??????
« Reply #7 on: 31 July 2006, 15:55 »
How do i up load pictures?
  • Unit
Re: How??????
« Reply #8 on: 31 July 2006, 16:01 »
photobucket.com - create an account - upload the pic - copy and paste the third box down with these [IMG ] tags in it, into your post.
Offline frog
Re: How??????
« Reply #9 on: 31 July 2006, 16:39 »
Think there called glider rails (the item that i need to remove from my seats and fit to this)
