Golf mk3
hardmonkeys
Fans cutting in after driving
Topic: Fans cutting in after driving (Read 975 times)
gitzy16v
28 July 2006, 13:31 »
As i said in a previous post i have just got myself a nice shiney16v. The other nite i had been out on a journey and had been home for about 15mins when the cooling fan started up. I went outside and checked it out and the engine was still quite warm. I put the keys in the ignition and the fans cut out i took them out again and the fans whirred back into life. This happened for about 3 mins then they cut out by themselves. I was gettin 36 odd mpg with the aircon running and the oil temp was 88-92 the water temp gauge was pointing to 12 o clock. Is this normal on the 16v as in my old 8v it never happened, or is it connected to the air con?
Any comments appreciated fellas
Dom Mk3
Insert wit here
Re: Fans cutting in after driving
28 July 2006, 14:00 »
normal I think. I regularly get the cooling fans turn on when I park up, and my thermostat is stuck open... Temperature rarely gets above 80!
richellis8valve
01 August 2006, 12:59 »
mine does that. local specialist says normal for the hot weather we r having
adyh
01 August 2006, 15:55 »
Fans in this weather should kick in . The reason they stop when you puty the ignition on is that the cause a load on the battery and wont help when starting the car.
Golf mk3
hardmonkeys
