Author Topic: drop in revs when air con deployed  (Read 1460 times)
Offline STOMMO
« on: 25 July 2006, 20:57 »
Hi
I have read elsewhere on this fine forum that when you switch the air con on that the engine revs rise. Well mine don't. In fact they drop down to approx 650, engine trys to stall then just manages to pick up and idle. Sometimes when I dip the clutch and brake sharply it actually stalls. It starts up again straight away, but its frustrating. Actually while we are at it how do you use the bloody air con any way. Whats that circular arrow next to the aircon switch? Does the air con use more petrol? My wife says it does but I don't know for sure which is frustrating as well! My wife says don't open the windows. In fact my wife says a lot. Which is frustrating. Any advice would be appreciated. Then I can put the good lady in her place.  :laugh: :laugh: :laugh: :laugh:
Offline V_Arse6
Re: drop in revs when air con deployed
« Reply #1 on: 25 July 2006, 22:35 »
Not sure where you read that - air con uses power, so turning it on will make the revs drop.  That said, it shouldn't make the car get near stalling - perhaps your idle speed needs adjusting.  :undecided:
To use:  Turn on air con, set temperature dial to cold (blue).  That's it.
'Circular arrow'?  Assuming you mean this is a button, it's probably the setting to recycle the air inside the car rather than get it from outside all the time (since it's already working with the cooler air-conned air in the car, it's got less work to do that way).
Using any accessories in the car diverts engine power for the purpose, but air con is particularly bad for this.  Not a huge difference, but quite a big one really (most accessories use so little really as to be pretty much un-noticable).  Running with air con all the time will probably reduce your mileage from a tank by 20 or 30 miles or more (educated guess - someone please correct me if I'm wrong here!).
As to why your wife says don't open the windows - I've no idea, unless it's p!ssing down with rain or something, in which case she has a point :laugh:  Or If the aircon's on, then it's a bit pointless to have the windows open too... although that could be you doing your bit to reverse global warming...
On the subject of windows - opening windows will make your car cut a less clean path through the air, leading to more petrol being used, but a car with all the windows down will still get more miles from a tank than the same car with the windows up and aircon on.
Personally I don't like Aircon.  I don't like the way it dries the air out - tends to de-moisturise me!  And although I don't actually have aircon in my golf, even with hire cars I'll tend to have the windows open and aircon off as long as I'm moving, if I've not got an aircon fan in the car with me.
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
Offline adyh
« Reply #2 on: 26 July 2006, 09:21 »
Turn the air-con on with the re-cycle button as well . The system works much better that way .
As to fuel effeciency , you will use more petrol with the system on , however having windows down dues cause drag.  The guidelines are generally anything below 40 mph , open your windows , and above close them and use the air-con .
Offline ellecria
« Reply #3 on: 27 July 2006, 14:08 »
Could be the first sign of a wiring loom failure!!
Does your stereo still work? If this has suddenly stopped working IÂ’d start to worry!
Happened to a mate of mine and he ended up selling the car on ebay.
Not a black ‘RÂ’ reg GTI with alloys on  from ebay is it :laugh:
cheers
ellecria :evil:
Offline STOMMO
« Reply #4 on: 27 July 2006, 17:15 »
ARRRGGHHHH!!!
Yes my stereo has just failed to work when my engine is running but works fine when the key is in the off position!!! ARRRGGGHHHH!!!! Yes it is a r reg black GTI 8v bought off ebay!!!!! Tell me your mate is not from Shrewsbury please!!!! I ve had the car for 12 months. I am now going to the local boozer to quaff loads of beer, I,ll be back later!!!!!
Offline STOMMO
« Reply #5 on: 28 July 2006, 13:30 »
Hi all
Don't take any notice of the last posting by ellecria. Its a complete wind up off a coupla of my work buddies. It napped me hook,line and sinker. I,m sat here now with donkeys ears on.  Thanks to the postings from the previous members. Its taught me a valuable lesson, from now on I,ll be extra vigilant.
Offline STOMMO
« Reply #6 on: 01 August 2006, 16:48 »
Hi
In answer to  Chipdeaths questionabout where I saw on this forum that revs rise with aircon operated.Its onpage 18 of the most popular topic"OIL LIGHT FLASHES AND CAR CUTS OUT"
