Author Topic: Corrado seats into a mk2  (Read 2487 times)
Offline Kamaya
« on: 24 July 2006, 08:47 »
Hi all,
Weighing up the purchase of front & rear seats from a corrado to put in the mk2 i'll be getting next month. I know this can be done, but how much work/alteration is involved, and are there any 'how-to' guides that anyone knows of?
Scott
"You are only young once, but you can stay immature indefinitely"
Offline Ozz
Re: Corrado seats into a mk2
« Reply #1 on: 24 July 2006, 09:41 »
Hi mate, best guide to fitting the rear bench in that i've found is here: http://www.matey-matey.com/corrado_seat_conversion.shtml.
Doesnt sound like to bad a job, gonna be doing it myself next month. And fronts go straight in!  :smiley:
Mk2 Gti 8v
Offline GolfChick24
« Reply #2 on: 24 July 2006, 09:44 »
the fronts are easy peasy itll take you five mins they fit in same as your originals, the bench however i think requires a little work and then you'll end up with a gap either side as its not quite as long. It is possible to purchase something to go in this gap, i think mj interiors make them, its just a little pillow type thing
Offline Kamaya
« Reply #3 on: 24 July 2006, 10:05 »
Fantastic. That's exactly what i'm looking for.
Thanks for your help both!
VeeDubGTI16v
« Reply #4 on: 24 July 2006, 11:15 »
the rears need some brackets welding in for the bottom of the back rests and the tops need the bit of bar the seat clips to extending a bit. the actual seats clip in to the holes already in the mk2 and the middle arm reast needs screwing in. it is quite a bit if work :undecided:
or you could just rest it all in place so it looks nice :laugh:
