Author Topic: i need a standard plastic dump valve  (Read 1364 times)
Offline burna
« on: 22 July 2006, 18:33 »
anyone got a standard re-circ dump valve for a golf gti turbo (agu code) ive got a forge re-circ on and it sounds boring, at least with the old plastic one it would chatter mint.
id take 45quid and a standard one for my forge. it aint a month old and i lost the reciept so i cant return it.
i know this thread should be in for sale but i being a mk4 section it would apply.
anyone interested just gimmi a ring on 07737071355.
cheers
see this....this......this is my BOOMSTICK!
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: i need a standard plastic dump valve
« Reply #1 on: 23 July 2006, 16:43 »
It was probably 'chattering' because it was foobarred!!!
A new plastic one won't 'chatter' either, because its' diaphragm won't be split!!! (For a short while, anyway).
Keep the Forge & buy an induction kit.  That way you will get chatter, & you won't be losing performance. :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline ryushi
« Reply #2 on: 24 July 2006, 11:01 »
^^^ He speak the truth!^^^
Don't try and find a dump valve that gives you a chatter/whoosh - the 1.8T engine is needs the air to be recirculated to certain sensors, like they guy above said if you want noise get an induction kit which will make it louder.
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #3 on: 24 July 2006, 16:49 »
If you want a standard dump valve, I got one mate, but like everyone says - it wont chatter, co for an induction and you will be happy, esp with a remap :cool:
Offline burna
« Reply #4 on: 24 July 2006, 19:55 »
god dammit, you lot were all right, i sold my forge, got my standard recirc back and yeah it was jammed. luckilly i got a standard one off a 225bhp audi tt, works fine.
would my engine fail quickly if i put the old recirc on that chattered, i presume its the turbo getting the boost forced back through it.
my mates cossie makes the same noise and i love it.
