General discussion
wheres my speed sensor?
Topic: wheres my speed sensor? (Read 2688 times)
DazVR6
mk3 VR6...FEEL THE GRUNT.
22 July 2006, 15:03 »
Anyone no where the engine speed sensor is located in a mk3 2.0 16v? is it on or near the gearbox/flywheel? i have a fualt code which tells me my idle rpm is to high do i change the speed sensor or can i adjust it another way?
Judderi
Guest
Re: wheres my speed sensor?
24 July 2006, 08:51 »
Isnt there an idle screw on the throttle? I would try adjusting this first.
DazVR6
25 July 2006, 02:14 »
ill take a look
AudiA8Quattro
Forum addict
25 July 2006, 11:18 »
Quote from: Mk2GTI2.016v on 24 July 2006, 08:51
No, ABF engine ECU sets the idle speed.
DazVR6
25 July 2006, 16:12 »
anyone no what i should do then? my car also just dies on me sometimes when stationary,be sitting there at the light and it will cut out and battery light will come on...any ideas? it always starts first time straight away.
AudiA8Quattro
Forum addict
ECU and Fuel Pump relays.
DazVR6
Reply #6 on:
25 July 2006, 16:16 »
this only started after having crank speed sensor replaced so wondered if this was related....ecu relay No 30, fuel pump relay 167..?
AudiA8Quattro
Forum addict
Reply #7 on:
25 July 2006, 16:18 »
Other way round, fuel relay 30, ECU relay 167.
DazVR6
Reply #8 on:
25 July 2006, 16:25 »
The heats getting to me.... :embarassed: cheers audi
AudiA8Quattro
Forum addict
Reply #9 on:
25 July 2006, 16:26 »
No problem, this is what you are looking for.
General discussion
