Author Topic: Bosch Distributor  (Read 3363 times)
Offline MikeyB
Bosch Distributor
« on: 21 December 2003, 15:03 »
Hi people,
I'm after some help with my golf mk1 (1093cc). The problem being the dizzy leaks oil along the shaft, so I was wondering a) is there an internal oil seal? b) if so how do you gain access and c) does anybody know of a repair kit for them?
Its a Bosch dizzy.
cheers,
Merry crimbo.
Offline mk1
Re:Bosch Distributor
« Reply #1 on: 21 December 2003, 17:15 »
Two options here, strip your 20 year old distributor and replace the seal, or go to the scrapys and get yourself a dizzy, wiring, coil and ign amp out of a Polo and have a better setup. Sounds like a lot of work, but it's not that hard and the reward would be worth it.
ps, I assume the leak is internal and not from the body to head "o" ring ???.
Steve.
Offline mk1
« Reply #2 on: 22 December 2003, 19:59 »
Oops, forgot to say, check the engine breather is clear as these engines were bad for choking them ;).
Steve.
old_boy
« Reply #3 on: 27 December 2003, 15:22 »
Hi Mikey,
if you get, stuck i have a dizzy spare you can have,
just need to cover P&P and its yours! ;)
HO-HO-HO! ::)
Offline MikeyB
« Reply #4 on: 30 December 2003, 22:44 »
Hi ya old_boy,
I think I'll take you up on that VERY kind offer.  :o :o ;) ;D
I took my dizzy apart yesterday and it?s not as simple as I first thought. I was hoping that there would be an o-ring seal or something similar but no. It looks like it?s a soft metal collar which is a sung fit around the shaft, doh.
What model is your dizzy? Is it machanical or electronic?
Cheers,
Mikey.
p.s All the best for the new year!  ;D
old_boy
« Reply #5 on: 31 December 2003, 06:18 »
hi there
send me a IM with the part no. and we can check its what you want! :)
