Author Topic: Peugeot 306 GTI-6 or MK3 GTI ... Choices Choices  (Read 23343 times)
Offline AudiA8Quattro
Re: Peugeot 306 GTI-6 or MK3 GTI ... Choices Choices
« Reply #30 on: 23 July 2006, 16:52 »
Just stating an opinion.
There's no way a 4 cylinder even tuned lump is gonna keep up with a v6.
Anyway i'm not into VW's that much anymore, i'm in to Audi's, and they have a chassis miles better than any golf including mk2's.
pmsl, you obviously, know what yer on about don't ya...... :grin: :grin: :grin:
"NOT"
Thats a convincing argument!!!
Would you like to explain yourself?  :rolleyes:
mowgli
« Reply #31 on: 24 July 2006, 14:09 »
Conclusive and independant proof:
http://www.306gti6.com/forum/showthread.php?id=46322&page=last
Sorry fellas, if you want the fastest car through the bends you bought the wrong one...
I also posted the question on another independant forum and the responses were 10-1 for the 306.  So, in summary, the 306 GTi6 is better than the GTi 8/16v and better than the VR6 too.
I'd still rather have the Golf though, better long term proposition.
Offline hitman
« Reply #32 on: 24 July 2006, 16:29 »
A 4 cylinder engine will not and cannot produce as much torque as a v6 motor, thats a fact.
OK fact boy explain this then......
Engine specifications of 2 rather decent German car manufacturers Both made about the same time (early 1990Â’s).  Theres so little to tell these two apart on paper other than the number of cylinders.
Engine
Engine Configuration   I
Cylinders   4
   Water-Cooled
Aspiration/Induction   Normal
Displacement   2992.00 cc | 182.6 cu in. | 3 L.
Valves   16 valves.
4 valves per cylinder.
Valvetrain   DOHC
Horsepower   208.00 BHP (153.1 KW) @ 5800.00 RPM
Torque   207.00 Ft-Lbs (280.7 NM) @ 4100.00 RPM
HP to Weight Ratio   13.8 LB / HP (Vehicles with similar ratio)
HP / Liter   69.3 BHP / Liter
Bore   4.09 in | 103.9 mm.
Stroke   3.46 in | 87.9 mm.
Compression Ratio   10.9:1
Main Bearings   5
Fuel Type   Gasoline - Petrol
Fuel Feed   DME ignition - fuel injection
Engine
Cylinders   6
Engine   Aluminum cross-flow bridge
Displacement   2964.00 cc | 180.9 cu in. | 3 L.
Valves   24 valves.
Valvetrain   DOHC
Horsepower   228.00 HP (167.8 KW) @ 6300.00 RPM
Torque   201.00 Ft-Lbs (272.6 NM) @ 4600.00 RPM
HP / Liter   76.0 BHP / Liter
Bore   3.48 in | 88.4 mm.
Stroke   3.16 in | 80.3 mm.
Compression Ratio   10.0:1
If you want to look the figures up for yourself thats a Mercedes SL300 and a Porsche 944s2 a 3 litre BMW of a similar age would show similar figures too.
Offline hitman
« Reply #33 on: 24 July 2006, 16:31 »
Oh and in answer to the initial question, shopping on a budget of £2000 look long and hard before you buy either a Golf or a 306, there likely to have had a hard life before they get to this sort of price.
The Mantra (not the Opel Mantra) is condition, condition and condition.
Offline HARDCOR3
« Reply #34 on: 24 July 2006, 17:34 »
AHEMMM, fast through the bends did you say, well check this VR6 destroy an Impreza thru the bends, you hang on to your little french dreams...... :smug:
http://www.filecabi.net/video/590hpgolf.html
 :wink: nuff said  :grin:
B.I.G DUB
« Reply #35 on: 24 July 2006, 17:45 »
is this really a row over a pug gti-6 and now vr's? :shocked: that vid of hardcore's says it all,plus the pug IS french!  :grin: i got a vr6 after an impreza turbo and i wont be going out anytime soon to change it for the pug! as for going thru bends,depends who's driving!!  :smug:
« Reply #36 on: 25 July 2006, 00:02 »
Engine
Cylinders   4
   Water-Cooled
Valves   16 valves.
Valvetrain   DOHC
Main Bearings   5
Engine
Cylinders   6
Valves   24 valves.
Valvetrain   DOHC
Ok boy, we were talking about a 2 litre 4 cylinder 16v against a 2.8 litre 6 cylinder 15 degree V, go back and read the thread from the start  :wink:
« Last Edit: 25 July 2006, 00:04 by audi100Quattro »
Offline hitman
« Reply #37 on: 25 July 2006, 09:10 »
But thatÂ’s not what you saidÂ….. :wink:
And I Quote;
Now obviously a standard 2.8 litre lump will push out more power than a standard 2 litre lump it would be daft to say that in this particular case the VR6 is less powerful than the Pug.  Anyway any argument is purely hypothetical as your not going to get to the point on the road where you would be able to test either of the cars to anywhere near there limitations, unless of course you fancy parking yourself upside down in the field next to where you left the road.
« Reply #38 on: 25 July 2006, 09:34 »
And I Quote;
Yes you are right, i stand corrected  :laugh:
What i should of said is a bigger v6 lump will produce much more torque than a smaller 4 cylinder lump.
However my statement is still wrong really as the VR6 isn't really a real V6 engine, did you know that?
In reality we are talking about road cars, not racing on a track, so the v6 in this case will be much more driveable, and will out accelerate the pug at pretty much any point in the rev range.
Offline V_Arse6
« Reply #39 on: 25 July 2006, 09:58 »
Bah.  Screw the pug - when you plant your foot in second it's not going to sound like the VR.  And that's what puts a big grin on my face :evil:
How many of us actually go around the corners anywhere near the limits of the car all the time?  hardly anyone (well, I hope anyway)...  But how many of us are going to floor it and grin on dual carriageways and straight bits of A road?  lots.
Just my $0.02. :wink:
'95 Mk3 VR6
FK Highsports, Crystal Clear Fogs/Indicators/Repeaters, Mk4 Style Headlights, PiperX induction, Bonnet lifters. (Need to update pic for new headlights)
