Author Topic: MK2 8V manifold/downpipe removal?  (Read 16509 times)
Offline Stu-dub
« on: 17 July 2006, 19:39 »
Just been told by an exhaust place that to cure the slight blow from my manifold and/or downpipe on my 1990 MK2 8V golf, it needs a mechanic as the rack needs to be dropped as the downpipe flange is bigger than the hole it has to drop through???
Any ideas?
Sounds a bit complicated for an old easy to work on golf?
Thanks,
Stu
Offline GTI-BOY
  • It's a love / hate relationship
Re: MK2 8V manifold/downpipe removal?
« Reply #1 on: 17 July 2006, 20:29 »
 The manifold will come off by removing six nuts from the downpipe/manifold join and then removing 8 (? I think) bolts from the manifold/head join.  Might be just gasket replacement at these points which is straight forward enough, however if the down pipe has a hole and needs to be removed then I think the steering rack is indeed in the way.
Blown Gearbox :(   Now replaced :)
Offline Stu-dub
« Reply #2 on: 18 July 2006, 10:18 »
So to fit a 4-1 manifold the rack needs dropping!  ??
I'll call my freindly mechanic methinks.....
Judderi
« Reply #3 on: 18 July 2006, 11:11 »
Yup. Its not really the rack but the engine subframe you need to drop. The subframe is only 4 bolts though and can be supported with a trolley jack while dropping it a little. The main worry is the captive nut the subframe bolts to. Sometimes the captive nut breaks free and just spins. So be carefull.
« Reply #4 on: 18 July 2006, 11:13 »
Oh if only it was that easy :grin:
You'll find that 7 manifold bolts will come out with a struggle, and the hardest one to reach will round off hopelessly.  4 of the downpipe bolts will shear off after some serious effort, one will come off with a struggle and again the hardest one to reach will round off hopelessly!
Anyway: To replace the downpipe you either have to lower the subframe a bit, remove the head from the engine, or pull the engine out.  You might get away with it if you remove the front engine mount and drop it forward a little, then try to squeeze it down the back.
Given the choices I'd go with removing the engine if you have access to a crane, it actually isn't that difficult to do!  The choice as they say, is yours ;)
Offline Mirage-
« Reply #5 on: 19 July 2006, 21:06 »
And if you're not careful and it spins? Seems a bit "weak" to be holding the suframe up surely?
« Reply #6 on: 20 July 2006, 11:48 »
then you have to chop a hole in the footwell and weld it back on!
Offline Mirage-
« Reply #7 on: 20 July 2006, 11:55 »
Ahh so it is fixable if this happens then  :grin:
Just that I'll be replacing the ARB soon and from what I could see the subframe needs dropping slightly in the process.
« Reply #8 on: 20 July 2006, 12:15 »
yeah fixable, but you just need a strong heart when you start chopping a dirty great hole in the footwell :grin:
Offline vitko.lev
« Reply #9 on: 17 July 2019, 16:33 »
Hi and sorry for asking after 10+ years with no answer in current thread ...
Did you managed to fit it finally?
I am planning to do this very soon, definitely won't take head off the engine.....
Is it possible without undoing the head?
