Author Topic: Golf ball gear knob  (Read 1040 times)
Offline fozzie
  • say my name slowly
Golf ball gear knob
« on: 15 July 2006, 11:39 »
Ok, I know this is a lame question, but if you don't know, then you don't know, do you? :embarassed:
I now have an original golf ball gear knob but when i went to fit it I found that the golf ball has no theaded part to match up to the gearstick. :cry:
So is this bit missing?
Or is the gear stick's threaded end a bodge by a previous owner?
Does your gear stick have a threaded end, or is it just a cut pole?
I could fin a bolt that fits the thread and then angle grind the out side edges off until it fits into the gear knob, or I could cut the threaded part of the gearstick off. If I cut the gearstick though the height will obviously be about 2" shorter and may feel wrong. :undecided:
So GTi owners with golf ball gear knobs, how does yours attach?
Reach around, it's only fair.
Offline rowlers
  • I'm back - MK7 GTI
Re: Golf ball gear knob
« Reply #1 on: 15 July 2006, 11:53 »
the gear knobs screw onto the thread on the end of the stick, so don't cut the thread off!
it sounds like the knob has been tampered with!
VeeDubGTI16v
« Reply #2 on: 15 July 2006, 11:54 »
the threaded bit does come out, sounds like yours has gone missing. maybe another vw knob has the same insert that you can pinch from down the scrappy?
Offline fozzie
« Reply #3 on: 15 July 2006, 14:26 »
aha!
fantastic!
thanks very much for that, it's a shame I cant play with the angle-grinder though :tongue:
thanks rowlers, thanks veedubgti16v
Off to the scrappy i go.
