Author Topic: Stupid Questions Time  (Read 1089 times)
Offline frog
« on: 14 July 2006, 21:53 »
Are the arches and side skirts the same on a small bumper model as they are on a big bumper model?
I have a switch in the passenger side tray that is attached to a buzzer, have tried switching switch and buzzer goes off but nothing else seems to happen any ideas?
How do you remove the front seats?
Offline Simpson
  • one day il learn
Re: Stupid Questions Time
« Reply #1 on: 14 July 2006, 22:32 »
no in response to furst question, and i have no idea what the buzzer is, does it have an immobiliser? and the front seats are removed in the middle of the seat subframe there is a 8 or 10 mm nut which needs undoing then the seats will slide back out of the runners  :smiley:
i must buy a new car!
mix
« Reply #2 on: 14 July 2006, 22:50 »
Its a 10mm bolt that holds it in place, you will also need a screw driver as there are some white clips at the back of the runners, these need to be removed so that they seat can then be slide backwards and out the runners when the front bolt has been removed....hope that makes sense
Offline JMallows
« Reply #3 on: 14 July 2006, 23:21 »
And the runner covers need to come off too :)
A clever person solves a problem. A wise person avoids it.
Veedubgt18v
« Reply #4 on: 16 July 2006, 13:45 »
and no the arches and side skirts arent the same lol
Judderi
« Reply #5 on: 17 July 2006, 12:36 »
And the bolt for the seats is at the front of the seat underneath where you sit.
