Author Topic: 8V CLUTCH  (Read 1629 times)
Offline gozzy
8V CLUTCH
« on: 19 December 2003, 20:59 »
My clutch has started to slip etc so is there anything I need to be aware off before I start doing the job. Or is this a mechanic job??
golfvr6
Re:8V CLUTCH
« Reply #1 on: 19 December 2003, 21:10 »
You gonna do it on your own? at least get someone to help.
Offline gozzy
Re:8V CLUTCH
« Reply #2 on: 19 December 2003, 21:11 »
it dont look that hard seems to be plenty of room. I did one once on a pug 205 no bother. although the Golf is a far better car than that ever was
golfvr6
Re:8V CLUTCH
« Reply #3 on: 19 December 2003, 21:15 »
Fairly simple, saying that allow a day to do the job. Don't take shortcuts.
Have you got lifting equipment?
A good tip is, the box will probably not come out without moving the engine over, so instead of moving the engine, when the box is unbolted and free, move it out slightly and rotate the diff up to miss the subframe when lowering it.
