Author Topic: PAS pump noise???  (Read 1707 times)
Offline 16v Matt
PAS pump noise???
« on: 12 July 2006, 13:18 »
When my valver has been running for while a whine appears alomost like the sound of an Eaton charger.   Now, I think I have narrowed it down to the PAS pump.........I think, lol
If I rev the engine there is a slight whine.  If I go lock to lock & rev it slightly at the same time it whines like a big whiney thing in a whining contest.   I take it the PAS pump is driven from the same belt as the water pump, so as the revs rise the pump is working harder?
Normal for PAS a pump on its last legs to be moaning, or have I totally mis diagnosed this??
Judderi
Re: PAS pump noise???
« Reply #1 on: 12 July 2006, 13:20 »
I think your on the right lines really. Id stick my head under the bonnet and rev away while listening.
Offline 16v Matt
« Reply #2 on: 12 July 2006, 13:23 »
Yeah will do, need a hand with that  though, my arms are'nt quite long enough to rev & steer while my heads under the bonnet! :grin: :laugh:
Offline Brads MK2 GTI
« Reply #3 on: 12 July 2006, 13:38 »
Well you could park it on full lock and operate the rev's with the throttle cable attached to the housing on the top of your engine?
Offline 16v Matt
« Reply #4 on: 12 July 2006, 13:43 »
Yeah could do, it only seems to do it when the steering wheel is being moved though.   The G/F can make herself useful later :wink:
Its the only time she'll be in the driver's seat with the engine running! :laugh:
Offline Daddycool
« Reply #5 on: 12 July 2006, 14:13 »
My power steering pump used to do this, turned out the hydrolic flued resivoir had cracked & was leeking slightly causing the pump to make nice super charger noises!!!!
Offline 16v Matt
« Reply #6 on: 12 July 2006, 16:01 »
Cheers daddy, I'll be checking it tonight. :cool:
