Author Topic: this noise = ?  (Read 1096 times)
Offline ghost8
this noise = ?
« on: 11 July 2006, 21:16 »
hey guys, need some help please,
with the weather as its been, the windows are down, and recently I been leaving me tunes off ?  (strange enough in itself).
I noticed a while ago a sound, that only happens on gear change, not really deep, but a solid volkswagen build quality sounding of what seems like something engaging - rod into slot?
Its relative to the stick movement, not clutch pedal movement, so mebbe the connector rod / gubbins need greasing or is it something on the way out?
I dunno, I lub me car but aint a car doctor type bod
your thoughts....?
'' but it's 'sposed to smell like that in the country ''
Offline Agreeable Slick
  • Unit
Re: this noise = ?
« Reply #1 on: 11 July 2006, 21:35 »
Possibly some of the gear bushes need replacing. Look in the maintenance and info section for a guide.
Offline ...joe
Re: this noise = ?
« Reply #2 on: 11 July 2006, 22:30 »
the linkage does make a nice mechanical noise when you shift gears but i doubt you'd hear it while driving.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Re: this noise = ?
« Reply #3 on: 12 July 2006, 08:40 »
Depends how loud your engine is and where you are, when driving round my work carpark with the tunes off and windows down I can hear it quite clearly.  Have a look at the gearbox while someone changes gears, you should be able to hear where the noise is coming from :)
It should be a nice clicky noise ;)
Offline ghost8
Re: this noise = ?
« Reply #4 on: 12 July 2006, 13:05 »
yeah as rubjonny says,  a nice solid click,  no accompanying sounds that would indicate alarm....
pulling up and leaving junctions etc. are the only times I get to hear it - sunroof only open usually, but slowing down for summer has given me more insight into me car,  you get to look longer at the hunnies aswell -
so it's normal then?
the noise , not the perving
