Author Topic: Pierburg Idle Speed - Again!!  (Read 970 times)
Offline keithyboy
« on: 11 July 2006, 09:23 »
I replaced the rubber carb mounting thing at the weekend as it was totally perished and causing rough and slow idling. I drove it briefly at the weekend and it seemed ok but this morning I have an hot idle speed of 2200 rpm. It isn't rough, it just idles at a rock steady 2200.
I'm guessing at an airlock in the cooling system around the carb, any other ideas?
Wrong wheels and mine's Calypso not snot but it's close enough
Re: Pierburg Idle Speed - Again!!
« Reply #1 on: 11 July 2006, 17:09 »
either that or the coolant channel o'ring in the inlet manifold has swolen and clogged the coolant system, check my pierberg post in the mk2 maintenance + info section :)
It may also be a faulty waxstat, if you remove it and chuck it in a tub of boiling water you should see the pin in the middle extend.  Doing this can also 'reset' a faulty one sometimes :)
