Author Topic: MOT Failure points need some advice pls :)  (Read 2257 times)
Offline monzablue16v
Re: MOT Failure points need some advice pls :)
« Reply #10 on: 10 July 2006, 11:59 »
Lol too many posts can you tell I need to fix it for the weekend :D
Judderi
« Reply #11 on: 11 July 2006, 15:11 »
Well if your a dab hand with a brake line flaring kit and have a propper pipe bender then its a DIY job. Personally i hate doing brake lines but if im skint i would do them myself.
« Reply #12 on: 11 July 2006, 16:56 »
you can't put 256mm rear discs on unless you get very custom...
only 4wd golfs had 256's on the back whereas the 2wd ones have 226mm :)
AWD Mk2s have 239x10mm solid discs on the rear, identical to 1.3 Golf front discs ;)
