Golf mk2
Engine knocking noise
Topic: Engine knocking noise (Read 1204 times)
Jaymapp16v
08 July 2006, 17:37 »
My MkII 16v has jst starting making a knocking noise! the noise is more of a tapet noise that gets louder and faster as the engine revs build up! i've had the rocker cover off changed all the tapets and both cams are in perfect condition! the noise is coming right from the top underneath the rocker cover but i can't figure out what it is! its not the right noise to be bottom end, and it is missing slightly. does anyone have any ideas!
Cheers Jay
golfmk2boy
Here all the time
Re: Engine knocking noise
10 July 2006, 10:52 »
Hi Mate,
Have you had your car tuned recently? - What is the condition of the timing belt like?...
Also, does the knocking continue when warm?
golfmk2boy
Here all the time
10 July 2006, 11:03 »
Also,
Doe sit get worse with higher revs, if it does it could possibly be the front of the exhaust / manifold problem.
jezza16v
10 July 2006, 11:11 »
Sounds like it could be a 'little' end on the way out or piston slap......
Jaymapp16v
10 July 2006, 18:06 »
no its doesn't get any better when warmer! and the higher i rev it, the louder it gets and faster it gets! thats why i thought it could be the cam or the cam followers! i'll take the head off this week, and work from there! cheers people.
Judderi
Guest
11 July 2006, 15:08 »
Did you soak the new lifters before installing them?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
11 July 2006, 17:20 »
did you fit a genuine/decent german brand oil filter the last time you did the oil?
Edit: And what oil did you use?
Last Edit: 11 July 2006, 17:25 by rubjonny
Jaymapp16v
Reply #7 on:
14 July 2006, 14:31 »
yea we did soak them made sure they were full of oil b4 putting them in, i used 10-40 oil i've even let the car run for a while after fitting the lifters to let the oil get to the top but it still makes the noise! i'm having these feelings its a valve sticking cause its slightly missing! and the noise is coming right from the top of the engine!
Golf mk2
