Author Topic: brake Light failure  (Read 2412 times)
Offline Stu-1.8T
  • Quit your Jibba Jabba
brake Light failure
« on: 06 July 2006, 18:34 »
Just come back from work and noticed that my brake lights have stopped working (even the high level brake light). :sad:
What could this be down to do you think? could it be a fuse or is there a switch connected to the brake pedal??.....pretty sure it's not all of the bulbs that have blown.
Thanks in advance
Stu
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: brake Light failure
« Reply #1 on: 06 July 2006, 19:00 »
Any of the other lights working?
Side, fog, indicators, reverse etc.?
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Stu-1.8T
« Reply #2 on: 06 July 2006, 19:16 »
Yes, Reverse and the indicators were working
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #3 on: 06 July 2006, 20:02 »
try your tail lights as stop and tail are normally on the same fuse
Offline Stu-1.8T
« Reply #4 on: 06 July 2006, 20:40 »
The tail lights are still working aswell........I hope this isn't going to be an expensive problem!! :undecided:
Offline GazB
« Reply #5 on: 06 July 2006, 20:44 »
could be the switch in your brake pedal :undecided:
Offline GazB
« Reply #6 on: 06 July 2006, 20:52 »
There is a switch at the back of the brake pedal that is probably broke, i think the part you need is 1J0 945 511 C
Offline Stu-1.8T
« Reply #7 on: 06 July 2006, 20:59 »
Thanks for your help guys.
Offline JAKESANGEL
« Reply #8 on: 07 July 2006, 16:11 »
Hello mate, the same thing happened to mine a few weeks ago and it was the brake switch behind the pedal my mate replaced it for me and its wasnt expensive but he did say 99% of the time its the switch that goes and not a fuse. hope it helps. one thing i would say is once its replaced make sure the brake lights come on as soon as you even touch the pedal slightly as mine didnt,  they can be adjustable anyway so its easy to amend. hope it helps
Offline MARKIV5
« Reply #9 on: 07 July 2006, 18:55 »
I had this problem a couple of years ago, took the switch of and gave it a dose of good old WD problem hasn't come back :laugh:
