Golf mk2
heater troubles
Topic: heater troubles (Read 4762 times)
harr1s
mk1 caddy and mk2 gti owner
heater troubles
23 March 2003, 20:23 »
the heater controlls on me mk2 dont seem to work very well . i can only have hot/cold air blowing on the screen or down on me feet the selector dosnet really select the others
has anyone got any ideas..
Harr1s............
Last Edit: 01 January 1970, 01:00 by 1055631600
richandhazel
Global Moderator
Forum addict
Re: heater troubles
23 March 2003, 20:57 »
Not sure what it tells you in the Haynes Manual, but is this any help?
http://homepage.ntlworld.com/richandhazel1/Heater%20control%20adjustment/Heater%20adjustment.htm
mo3000
Guest
Re: heater troubles
23 March 2003, 22:33 »
It could be one of the clips that holds the cable outer has come off. If you look at the pics rich has put on you can clearly what i mean.
It happened to me on a polo, so Its worth a look at.
harr1s
Re: heater troubles
23 March 2003, 22:40 »
had a look at the page cheers rich, mo3000 ill have ago at fixing it at the weekend...............
? ?Cheers................
? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?Harr1s..................
Last Edit: 01 January 1970, 01:00 by -1
goldfinger
Re: heater troubles
25 March 2003, 21:52 »
Had a similar problem on my MkII mate.
The lever on the heater wasn't working, it blowing air just fine tho'. My mechanic had a look and said that the cable on the inside had broken. He fixed it in no time.. n' didn't cost sweet FA!
Golf mk2
heater troubles
