Author Topic: my polo 16v is sick  (Read 1207 times)
Offline markdono
my polo 16v is sick
« on: 05 July 2006, 21:26 »
my polo 16v is very jumpy. sometimes it happens when am pulling off from lights but most of the time its when im driving along and decide to go faster it sounds and feels like the engine is smothered.i might have put to much oil in when i top it up last would this be the problem? the breather pipe at the top of the engine looks very oily this pipe goes into the air filter box at the top of the engine is it possible that oil has got into the butterfly valve in the same box?is it possible to clean this easily or should i bring it to a mechanic,any help would be great! thanx
Offline AudiA8Quattro
Re: my polo 16v is sick
« Reply #1 on: 05 July 2006, 21:30 »
Is that engine fitted with an airflow meter (MAF), if it is, that will probably be your problem.
Remove it, and spray it with carb cleaner to get rid of the oil coating.
Offline markdono
« Reply #2 on: 05 July 2006, 21:35 »
i was told before it has an air flow meter ,would you know where in the engine bay it would be ,there is not a lot of room around the engine to get to anything
« Reply #3 on: 05 July 2006, 21:37 »
Post a pic and i'll point it out.
Offline markdono
« Reply #4 on: 05 July 2006, 21:46 »
how do i post a pic i havent a clue
« Reply #5 on: 05 July 2006, 21:49 »
Write the link for the pic between [img] pic [img]
Offline markdono
« Reply #6 on: 05 July 2006, 21:54 »
Offline markdono
« Reply #7 on: 06 July 2006, 21:03 »
fixed the problem it was the throttle body ,bought some carb and injection system cleaner spray,sprayed it directly into the throttle body houseing like it said to do,worked a treat!!!!!! thanx for the help audi100Quattro
« Reply #8 on: 07 July 2006, 00:13 »
Nice one  :cool:
