Author Topic: screws!!!!  (Read 1066 times)
Offline new2vw
screws!!!!
« on: 05 July 2006, 20:47 »
can anyone tell me on average, how many turns out their throttle screw and air flow sensor screw are out roughly, as mine on the throttle housing are 3 turns and on the air flow half a turn out. 8v digfart........... Any help much appreciated, thanks  :undecided:
« Last Edit: 05 July 2006, 21:40 by new2vw »
goslow
Re: screws!!!!
« Reply #1 on: 06 July 2006, 10:08 »
The afm should be roughly in the middle, and the t'body depends how well your ISV is working.
If you think it isn't right, check the state of your vacuum hoses and make sure the t'body is resting up against the stop, on mine the idle switch was too far in holding it open slightly.
If the timing is off it also throws everything out a fair bit too!
