Golf mk4
Golf mk4 TDI
Wazzzer
Why now should it sound so noisy
Topic: Why now should it sound so noisy (Read 5420 times)
teash
03 July 2006, 22:58 »
After buying my mk4 I thought i`d do the decent thing and give it an expensive oil change (even though it has FSH) but since the oil change it rattles like a snake on start up. So have I put the wrong type of oil in (castrol edge) or being an imported car should I have opted for the longlife option oil?
adrian mick
Just got here
Re: Why now should it sound so noisy
05 July 2006, 03:07 »
make sure you used the right spec oil which is 505-500. that would be on the bottom of the castrol oil can. check this as soon as possible as you could be causing serious engine wear
teash
05 July 2006, 17:02 »
Cheers for that Aidy, oil spec says its 505-01, which is what it says in the handbook as well. So is it the right oil for the car or not?
Golf mk4
Golf mk4 TDI
Wazzzer
