Author Topic: clutch slave cylinder  (Read 3464 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 01 July 2006, 11:58 »
i got a small leak think its from the clutch slave clinder, can some one point out where it is,  the leak is a watery brake fluid type.
<<<Big Build Thread>>>
Offline The Doc
  • E63s Estate - Vito Sport
Re: clutch slave cylinder
« Reply #1 on: 01 July 2006, 12:06 »
Are you sure it's not brake fluid - Someone really has got it in for you mate  :shocked:
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 01 July 2006, 14:09 »
brake fluid and clutch fluid are the same thing... they share the reservoir.
You'll find the clutch slave on top of your gearbox pointing into the box to opperate the pressure plate on the clutch itself.
you can disconnect the pipe from the slave cylinder easily by just uncliping the securing peice and pulling it free. this could of come loose already which is why it's leaking.
is the clutch opperation still fine?
Mk4 Golf 150PD
Offline nadlad
« Reply #3 on: 02 July 2006, 00:34 »
clutch is perfect, i have had the car lowered so could it be coming from the drive shaft as once the car is lowered the driveshaft becoems slightly bent?
