Author Topic: Major Fuel Problem  (Read 1292 times)
Offline JB G60
Major Fuel Problem
« on: 01 July 2006, 00:19 »
Hi,
My Golf is actin rotten at the momemt, she starts up after about 15-30 seconds of turning over and idles roughly if i go to rev it, it will just die straight away, the injectors looked a bit worn so I replaced them with some off ebay along with the fuel pressure regulator switch. New fuel filter aswell. Its a G60 conversion by the way, anyone have any ideas?
Thanks
Offline takethefifth
Re: Major Fuel Problem
« Reply #1 on: 01 July 2006, 02:57 »
Do G60's have a blue temp sensor?  If its based on an 8v digi i would guess so....  Yeh worth replacing it anyway if you have one, or i think its actually called the coolant temp sensor. If its fried, the ecu will not choose the appropriate mix of fuel/air for engine temp and so run like a dog.
« Reply #2 on: 01 July 2006, 09:50 »
Yup they do, get it replaced:
025 906 041 A - £9.68+VAT
Offline JB G60
« Reply #3 on: 01 July 2006, 12:19 »
Ok, bit slow when it comes to the mechanic work, How would i go about finding and removing the blue temp sensor?
Thanks for the help
Veedubgt18v
« Reply #4 on: 01 July 2006, 12:37 »
its on the front of the cylinder head on the flange that the water pipes run in to. its held in by a little clip that pulls out then the blue thing lifts out
Offline JB G60
« Reply #5 on: 01 July 2006, 13:33 »
Replaced the blue temp sensor, no difference, car will start revs will go up and down a bit for about a minute then just cut out. any hint of a rev by me and it cuts straight out aswell.
« Reply #6 on: 01 July 2006, 23:50 »
Was it a genuine VAG one you replaced it with?  I had the same problems caused by a sh!tty GSF sensor.
« Reply #7 on: 02 July 2006, 09:26 »
check the idle switch clicks when the throttle is closed, and the wiring gets 5v with the ignition on.  Also check the throttle switches are actually working with a multimeter.
