I'd already mentioned in another thread about the problems I've had with my new 8v:
http://www.golfgtiforum.co.uk/index.php?topic=42852.0Well I picked it up from the garage this afternoon and although the leak was done, and the brakes are now up to scratch, the MAIN issue I had with the handling/steering feels just as bad as it did before.
In a nutshell, my gripe was that the steering felt too loose, with too much 'play' on the wheel - which I have to admit has been improved by the repairs. However in addition, while I'm driving along, the car
feels like it is lurching to one side or the other, and it's still doing it now - the best comparison I can make is the feeling the car has when you catch a brief side wind and the car does an unexpected wobble. It does it most noticabley when I'm going in a straightline at any speed. I can't tell whether it is just when the car goes over a bump or impection in the road or not, but it does seem to happen more on uneven roads or where there are slight dips and rises in the tarmac... but it is so unnerving that I don't want to drive it. Weird little characteristics I can live with, quirks are fine with me. But this just feels completely wrong and just a little bit scary.
Today the local VW dealership did the following to the steering (aswell as fixing the leak, sorting the brakes etc):
- Both frontside track rods
- Both boots
Cost me almost £300 inc labour for just the above and I'm no further fowardÂÂÂ
On the printout/invoices they gave me there was two extra things that were mentioned as needing doing, namely "play in the top steering bush", and also "suspect play in front suspension top mounts".
Previously the dudes at the garage mentioned a defect in the rim of one of the rear wheels, so I've changed both rear wheels from my 16v and put them onto this one. Previously it was running on low profile tyres and so now it has two low profile on the front and two regular on the back. Identical BBS RA alloys on both. It's also lowered by 40mm (according to the previous owner) on Bilsteins. No difference has been apparent after putting the two normal wheels on the back.
Right now, I've spent £1370 on the car plus £625 on repairs - £1995 altogether. I really need some advice on how to now proceed. Aside from the bizarre steering there's nothing else immediately wrong with the car, certainly nothing that needs doing immediately. But I feel utterly depressed after today about it.
Are these symptoms that anyone else recognises, or maybe has a good idea about might be causing it? I'm so fed up it's not true. I just don't want to spend the near future chucking my money at a problem that I can't work out the cause of...ÂÂÂ
