Author Topic: help help help whats goin on  (Read 1397 times)
Offline craig g
« on: 28 June 2006, 18:18 »
just changed by battrey cos it was dead and now the rev counter is dipping down 450 then back up too 900 its goin nuts can any one tell me whats wrong it does settle but as soon as stop after movin its off again   :sad:
craig gTI
Offline New Duncan
Re: help help help whats goin on
« Reply #1 on: 28 June 2006, 22:23 »
I gave instructions about changing batteries some time ago. De-powering can cause problems.
Use the blasted search button to check what you are doing before you do anything else.
I dont know your problem, could be a sensor not responding when powered-up, ECU playing up, cold start sensor device on the blink.
Hang in there, somebody here will know where you should look.
Duncan
BMW 325 Coupe Sport, Lux pack, Alpina manifold & throttle bore - Cosmo
VW Golf Mk4 1.8 turbo - Silver - AUM / ko3s
Offline craig g
« Reply #2 on: 29 June 2006, 17:43 »
i had the AA come out and they cleared a low voltage error
its still doing it but not as bad ..
he mentioned the car may remap its self when driving at different speeds is that right :undecided:
craig gTI
Offline GolfGL
« Reply #3 on: 29 June 2006, 20:57 »
Ive had my battery in and out loads and  never had a problem. I know the vws have a learning ecu so disconnect it again neg, then pos, reconnect pos, then neg. Take it for a fast drive and see if it helps if not possible sensor/fuses and and expensive vw diagnosis.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline craig g
« Reply #4 on: 29 June 2006, 21:22 »
thanks guys but found the problem
had a new samco sport dump valve on a development trial because i used to work there
and for some reason it was leaking...
should of checked that first  :embarassed:  sorry
craig gTI
