Golf mk2
Leak from rear light (me thinks ?)
Topic: Leak from rear light (me thinks ?) (Read 2283 times)
Uruk Hai
28 June 2006, 17:48 »
It would appear as though my rear driver side light cluster is starting to let in a bit of water every now and then, is the best and easiest fix just to get a new gasget from VW (are they still available ?)or does anyone know another better, simpler or easier way of curing this problem, thanks
Uruk Hai
Re: Leak from rear light (me thinks ?)
28 June 2006, 20:12 »
Anyone ? me carpets starting to whiff a bit
Agreeable Slick
Global Moderator
Serious forum addict
Unit
28 June 2006, 20:50 »
scrappy and pilfer one.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
Judderi
Guest
29 June 2006, 14:40 »
Might sound a daft question but is your rear washer working?
Uruk Hai
29 June 2006, 16:34 »
I know what your getting at mate and it worked fine the last time I used it, if it was the washer fluid I would notice the smell and colour wouldnt I ?
Judderi
Guest
30 June 2006, 08:27 »
Depends if you use screen wash or just plain water.
eightvalve
Reply #6 on:
30 June 2006, 09:20 »
Mines leaking in the exact same place. If you find a cure...let me know!
1989 Mk2 8v
Uruk Hai
Reply #7 on:
30 June 2006, 11:29 »
Sorry I should have been clearer, I do use screen wash in a 50/50 mix and its blue and stinks. When I put the car in the garage the other night I just left the boot wide open and propped up the carpet to give it chance to dry out butif its happened once there no reason why it wont leak again
A7 UFO
Reply #8 on:
30 June 2006, 11:54 »
Remove the lens and add some sealant gel (name escapes me). It doesn't act like a glue but purely as a air tight sealant. They all came with this from the factory but obviously if you have had lenses on and off this would need to be renewed.
Daddycool
Reply #9 on:
30 June 2006, 11:55 »
Screen wash is for girls!!!!!
Golf mk2
