Author Topic: GY Eagle F1's GSD3 205/55/16 Tyres  (Read 1848 times)
Offline New Duncan
« on: 28 June 2006, 14:18 »
Hi,
An Old Chestnut this one - but who knows ?
Just fitted 4 new Eagle F1 tyres to my 2001 turbo, had 70% worn P6000's on the back with cracked side wall all around the circumference where the tread starts and 1/2 worn Mich pilots on the front, one of which had a side wall patch repair on it ! on the inside so could not see it when negotiating the purchase.
Aquired the AUM Turbo a month ago with dodgy tyres but an MOT only 200 miles before purchase ? hmmm
The F1's are noisy just now, particularly on the motorway above 60 but noise drops off above 100.
Questions:  Sorry for that.
1) Do they bed-in and become a little more relaxed with mileage and time ?
2) What is the best pressure for these at the Front  ? when 2 people on board, load aprox 21 stone.
3) What is the best pressure for these at the Back   ? same load +  about 2 stone luggage in the boot.
Please do not quote the manual at me ! I'd like to hear from folks who use this F1 GSD3  tyre or have some personal experience of F1's GSD3 tread pattern.
I'm not keen on the noise, it is a warm day today, surface tarmac is warm.
Your comments please folks
Duncan
BMW 325 Coupe Sport, Lux pack, Alpina manifold & throttle bore - Cosmo
VW Golf Mk4 1.8 turbo - Silver - AUM / ko3s
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: GY Eagle F1's GSD3 205/55/16 Tyres
« Reply #1 on: 29 June 2006, 00:21 »
I moved onto Bridgestone Potenza RE720's for exactly that problem of road noise from the GSD-3's.  (Plus, I'm convinced the sidewalls are a little softer on the F1's).  They will get a 'bit' better with time, but won't be perfect.  I had 6 F1's on the bounce; they are a very good tyre - Then I decided to try 4 RE720's, & couldn't fault them.
My new 18's came with GSD-3's all round; could have been a lot worse!
But when they do wear out, I'll be replacing with 720's.
As with pressures on the 16's/F1's, I always liked 2.1 BAR all round, myself. (What's that..... About 32 psi???)
I've never carried any big loads, BTW.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline New Duncan
« Reply #2 on: 02 July 2006, 20:25 »
Thanks Ivor,
I go with 1.9 bar on the stern to get more tyre tread on the tarmac.
They have improved with a warm-up and 220 miles of fast manoevering on sticky rads this week-end.
They are good, bot the hype is stronger. Next time....I'm up for Pirelli PZero Negros with the soft compound. I'm more interested in driving 10k with more fun than 18k a tad more carefully.
F1's make noise on some tarmac surfaces (don't talk to me about those wretched concrete motorway surface)s - remember that folks.
That's how I see it.
Duncan
