Author Topic: lag on acceleration sometimes. + bad idle ?  (Read 2165 times)
Offline Overseer
« on: 16 December 2003, 12:05 »
some times when i plant my foot the car doesnt respond at all for a second.. (other times its.. wooohooo).. its like its lagged..
also.. if i've been driving at high revs for a bit and come to a stop the car doesnt always settle back to idle right away.. its not racing per se, but its just like its not willing to idle... (well kinda idles around 2000 instead of 1000)
pretty intermittent, but they seem related.. and generally in both cases i get the feeling somethings bit dirty or sticking?
« Last Edit: 16 December 2003, 12:09 by Overseer »
i-espedair
Re:lag on acceleration sometimes. + bad idle ?
« Reply #1 on: 16 December 2003, 15:25 »
Depending on where you drive / live, what mileage you do and what induction set up you got. My bet is it needs a good clean out.
If you live in a buit up area air polution can be greater and although its not much over years fine carbon particles in the atmosphere build up to create alot of sh!t in ya engine.
If you do more mileage the chances of this happening increase.
If you have a K&N or similar filter fitted you are suckin in more air = more polution. Although the K&N and similar filters have very good filtration the volume of air intake is greater and carbon build up will occur quicker.
When i bought my car she had done 50k mainly poodling round south London. She was idling badly and lagging on pickup, even stalling in low revs. Cleaned out the induction system and the throttle body and the difference was astounding. Like driving a brandnew car. Instant responce and perfect idle.
My advice is, take out the induction system and clean it all out, replace the filter if necessary. I use a K&N pannel filter.
Dismantle and clean out the throttle body. This takes about an hour and a half to do properly, i used a peice of fine cotton rag, some carb cleaner and some WD40. If you use the WD40 last and wipe it all clean it should leave a nice friction free film, helping to protect and limit carbon buid up. Could be Bo!!ox but makes me feel better. Follow the Haynes instructions on getting it apart and back together again.  ;D
Give it a try, hope this helps!
golfvr6
« Reply #2 on: 16 December 2003, 16:29 »
Good advice there. Also check for leaks around the throttle and intake.
Offline Overseer
« Reply #3 on: 16 December 2003, 20:14 »
hmm i had heard mention of the throttle body being cleaned out here before.. kinda thought it might come up..
as far as i know the air filter is standard.. when it does the lag thing it does kinda remind me of the lag i used to have with a K&N i put on my old car for a bit.
i'll take a poke at both when i've got time.
