Author Topic: 16v wont start when warm  (Read 1117 times)
Offline mk2mk4golf
« on: 27 June 2006, 18:37 »
hi new to the forum so here goes
 i have a 1991 16v golf 3 door in grey  just had the head rebuilt  and now when it is warm  it wont start turn the key and sounds like a flat battery sound  do you think i could be out with the timing marks   what i noticed was when i was putting the timing belt on and lined the mark on the flywheel up the mark on the cam would not line up so i had to put it a tooth out should i have gone the  other way   or  could it bee something  else  hope this makes  sense
 thanks  gareth
Offline mk2mk4golf
Re: 16v wont start when warm
« Reply #1 on: 28 June 2006, 20:52 »
what nobody can help
Offline jezza16v
« Reply #2 on: 28 June 2006, 21:33 »
Hmm..... I don't think you line up the marks on the toothed cam pulley and crankshaft pulley with each other. The toothed cam pulley lines up with a mark on the camcover and the mark on the crank pulley lines up with a mark on the block. There should be no doubt as to which is the correct belt position, one tooth either way and its usually well out. Done a couple of these now and never had an issue (the 'flywheel' is not used in this operation). You sure the cam sprockets/chain are lined up OK as well? You sure you have the right belt?  :undecided:
