Golf mk2
Ignition Mod
Topic: Ignition Mod (Read 1066 times)
Godzilla
<<<VR6 MADNESS>>>
Ignition Mod
26 June 2006, 16:04 »
What is an ignition module and will it help start my car when hot??...as im still having a few troubles with starting.
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Ignition Mod
27 June 2006, 09:08 »
Its located under the small plastic cover in the scuttle area, and it tells the coil when to generate a spark. I doubt it will be the cause of hot starting problems though!
Last Edit: 27 June 2006, 09:10 by rubjonny
Godzilla
<<<VR6 MADNESS>>>
Re: Ignition Mod
27 June 2006, 10:36 »
Thanks mate!! Will it help any starting troubles as replaced the fuel pump relay. There is an ignition mod' going on e.bay for very cheap and wondering if i should get it??
rubjonny
10k hero
Re: Ignition Mod
27 June 2006, 11:11 »
Well they're the same on all MK2s, so if you have a decent scrappy near you just pocket a couple! They arn't really worth much second hand.
Golf mk2
Ignition Mod
