Author Topic: ABS light on dashboard.  (Read 1460 times)
Offline jones_ga
« on: 25 June 2006, 11:10 »
Hi, I had my MK3 Golf GTi serviced in March and they told me my pads had about 3k left in them.  About 3k later (last week) the ABS light came on so yesterday I changed the pads. The ABS light is still on though. Do I need to get it reset on VAGCOM or is it likely to be something else?
Thanks
Graham
Offline monkeyalan
Re: ABS light on dashboard.
« Reply #1 on: 25 June 2006, 12:59 »
it's more than likely one or more abs sensors has packed in/got dirty. £35 each and pretty easy to change (sometimes)
Offline jones_ga
« Reply #2 on: 26 June 2006, 08:03 »
Thanks mate.
Just wondered as it was strange that the light came on when the pads needed changing
Offline adyh
« Reply #3 on: 26 June 2006, 09:05 »
You dont need to reset the ABS , the light should disappear after a couple of yards .
Offline Morgan GTI
« Reply #4 on: 26 June 2006, 16:47 »
I had this problem too (1 sensor replaced sorted it). Strangely whenever it happens now, I switch off and restart and the light stays off!
'95 MK3 16v 3dr in Dragon Green
Offline jones_ga
« Reply #5 on: 27 June 2006, 10:06 »
I'll have to try replacing one of the sensor's then I suppose.  It's still lit after 4 / 5 days.
Offline monkeyalan
« Reply #6 on: 27 June 2006, 14:03 »
if you can work a multimeter you can check which one it is. not sure what the resistance is meant to be but there are a few threads about it if you search.
Offline AudiA8Quattro
« Reply #7 on: 28 June 2006, 00:10 »
If any sensor is faulty you will get an infinity reading on the multimeter set to resistance, or in other words sod all  :grin:
