Author Topic: Has anyone ever........  (Read 1303 times)
Offline Davo13
« on: 24 June 2006, 23:00 »
Managed, whilst driving to shake there starter motor out of position?
Parked up went to the the shop came out got in the car tried to start it, nothing.  I thought... another starter motor, but the last one that went gave me plenty of notice.  So I thought i'd have a look under the bonnet, and low and behold the starter motor is hanging out.  What the fu@k I here you say...exactly and there's a flying pig!
To many sleeping policemen around here if you ask me.
I've lost one bolt, the thread on the other is knackered in the middle and the ring/washer type thing in the center of the long spindle thingy is now a little wonky.  If I put this back where it should be do you think it will work?  More to the point if I can get knew bolts to fit the starter motor back on will it work?
What about damage to the cogs in the engine, or any other internal parts?
Will I need to and how will I re-thread the parts of the engine block the starter motor bolts screw into.
This starter motor has been on for about 8 months and when I took the original one off the engine dropped a little.  what damage may have been caused when the engine dropped whilst driving?
Up to now I have manged to fix things that have gone wrong, myself...I may of met my match this time.
Any tips ideas, inspiration is greatly appreciated.
For the record it is a MK 2 1990 8v GTI
 :cry: :cry: :sick:
Offline Dizzie
  • Make friends with your fast
Re: Has anyone ever........
« Reply #1 on: 24 June 2006, 23:21 »
sounds like whoever fitted it didn't do a very good job. those bolts are partly responcible for securing the engine into the car.
if the threads are dodgey you should replace the bolt :)
Offline Agreeable Slick
  • Unit
« Reply #2 on: 24 June 2006, 23:22 »
Aye the long bolts go into one of the mounts IIRC> you will need to get new ones and replace the lot. Starters are not expensive and easy to replace. Just need to support the engine.
Offline Davo13
« Reply #3 on: 25 June 2006, 00:18 »
Where is the best place to get a starter from at a decent price, a company that will post it?
Thanks
  • Unit
« Reply #4 on: 25 June 2006, 00:19 »
have a look on GSF, and ECP websites.
Offline [han]
  • Graphic Designer for Haribo
« Reply #5 on: 25 June 2006, 07:27 »
i keep losing the wire on my starter i t hink, meaning she ownt even turn over, the first time it happene was at college near mechanics,  but they cudn't help? so had to call rac, he wiggled my wire! :wink:  and away i went sorted now!
« Reply #6 on: 26 June 2006, 08:28 »
As slick says the starter mounting bolts thread into the front engine mount bracket, so I'd get another one of those from a scrappy or the wanted forum.  Check out the front mount too, perhaps it's loose/damaged and is the cause of the bolts working themselves loose?
