Author Topic: 22mm cylinder and 9"servo help !  (Read 1637 times)
Offline Dave_P
« on: 23 June 2006, 21:07 »
hi all, i`m a new member here, i been using this site to get tips on doing work on my mk1 cabriolet, wicked site, very helpful, but i need need some help in fitting an upgrade break system. i`ve fitted a 9" servo and 22mm cylinder to my car but i come across a problem. the old cylinder on the cab has 2 break lines going into it from the under side and 1 from the side (2 for the front and 1 for the rear) on the new 1 it has 2 either side, so where do i connect my lines into this ? does it matter ? is the pressure disribution ok for the lines to be connected anyway ? obviousley i`ll have to block 1 outlet, and are the lines tightend to a torq ? any insite would be great, i tried doing a search but i only come up with discusions...  i`m sure this would be good information on other petrol heads wanting to do the same.. cheers, dave..
Re: 22mm cylinder and 9"servo help !
« Reply #1 on: 24 June 2006, 09:56 »
You can use brake circuit combiners off a MK2 which will allow you to plug 4 circuits into 2 outlets, but you'll still have the brake light switch to worry about.  I think you can get a pedal mounted switch of a Scirocco?  Anyone know?
Offline kraM
  • It's not the speed, it's the sudden stops...
« Reply #2 on: 04 July 2006, 13:31 »
Hi
You may have sorted it by now, but if you haven't, here goes
Find a skyrocket, grab a hacksaw and chop off the brake light switch bracket, maybe grab the brake pedal aswell, (dunno if it is different)  Find the brake light switch wires from the back of the fuse box and extend them accross the dash to the brake pedal.  Drill and bolt the switch bracket to your steering support bracket.  The master cylinder should have come with two blanking screws for the outputs.  I didn't use these and re-did some of the brake lines, basicly the general rule is to have a split diagnal circuit, so if one fails you don't loose one side of braking should they fail.
-------------------HEALTH AND SAFETY BOLLO*KS-----------------------------  If you are un-sure don't do it, really, not being able to stop really sucks, gets crunchy and could cause all sorts of problems.
Hope this helps mate
kraM
It's not the speed... it's the sudden stops...
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #3 on: 04 July 2006, 14:25 »
I was reading this thinking to myself "Damn this sounds familiar"
http://www.clubgti.com/forum/showthread.php?t=94619&highlight=servo
I think he's sorted  :wink:
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
