Golf mk2
High idle 16v
Topic: High idle 16v (Read 2757 times)
Alexg40
GTI forum regular
High idle 16v
15 December 2003, 17:34 »
Merry Christmas!!
My 89 16v today started idling at about 1100rpm. Any ideas??
visit dubcircle.net
Gambit
Forum addict
Re:High idle 16v
16 December 2003, 11:45 »
idle for a 16v is 950/1050rpm when upto to operating temp, just give the idle screw a small tweak clockwise and it will lower it
it will idle higher in cold mornings (cold starts) but this will eventually drop as the engine gets upto temp
Last Edit: 16 December 2003, 11:48 by Gambit
Alexg40
GTI forum regular
Re:High idle 16v
16 December 2003, 17:27 »
Yes well, yesterday it was doing it after a 25 mile run down the motorway, so it was pretty warm!! Today it hasn't done it at all. I'm a bit confused by all this 16v malarky, I'm a G man meself! Has anyone else had this prob??
visit dubcircle.net
golfvr6
Guest
Re:High idle 16v
16 December 2003, 18:44 »
Check for air leaks around the throttle body and inlet, also check ISV.
Alexg40
GTI forum regular
Re:High idle 16v
16 December 2003, 18:48 »
By ISV I assume you mean Idle Stabilisation valve?! How and what do I check??
visit dubcircle.net
Alexg40
GTI forum regular
Re:High idle 16v
19 December 2003, 17:54 »
Help me please!! I know bob all about these 16v thingies!!
visit dubcircle.net
Jon16
Re:High idle 16v
Reply #6 on:
19 December 2003, 17:59 »
Does the idle stay fairly constant once it's at 1100 rpm? If so it probably justs needs the idle screw turning down slightly to about 1000rpm - its on the throttle body. People turn it up slightly in winter when you have a higher load (heater, lights, rear de-mister etc) to stop the car stalling at lights, when parking etc. The screws tend to be a bit loose and can adjust themselves slightly (some people even put a speck of pain on them to stop unwanted movement). However, if the idle is erratic then it is probably the (expensive) idle stabilisation valve.
Alexg40
GTI forum regular
Re:High idle 16v
Reply #7 on:
19 December 2003, 19:42 »
It's not like it has gone up and stayed up. This morning it did it, but tinght it was back at around 900rpm.
visit dubcircle.net
Gambit
Forum addict
Re:High idle 16v
Reply #8 on:
22 December 2003, 08:55 »
just disconnect the ISV and try running it
ive been running mine for about 6mths or so without it
Alexg40
GTI forum regular
Re:High idle 16v
Reply #9 on:
23 December 2003, 23:35 »
That's just it!!! I don't know what it is or where it is OR how to diconnect it!!
visit dubcircle.net
Golf mk2
High idle 16v
