Author Topic: Altenator?  (Read 1167 times)
Offline kkh120
Altenator?
« on: 20 June 2006, 17:24 »
I was having a problem on the 16v with the battery not charging. Put the meter across it and was only getting 9v under load. Replaced with second alt. and still only getting 9v under load.
When I revved to 3.5k suddenly was getting 13.5V.
Put the old one back in to check and got 13.5V at 4K revs.
Do you know why it takes such high revs to get the alt. to start charging the battery?
Should I be looking at something else?
Cheers.
Mk2 8v and 16v.
Always looking for bits!
Offline Dizzie
  • Make friends with your fast
Re: Altenator?
« Reply #1 on: 20 June 2006, 17:32 »
the 2nd alternator could be just as faulty as the first
I would replace the earth strap from the engine to the chassis aswell just as a precaution. having a corroded or worn one can upset loads of things electrical
Offline Gozza
Re: Altenator?
« Reply #2 on: 20 June 2006, 21:01 »
Do you think the earth strap being eroded could stop the horn from working ??
Offline kkh120
Re: Altenator?
« Reply #3 on: 23 June 2006, 15:27 »
Any other ideas apart from the earth strap?
Mk2 8v and 16v.
Offline kkh120
Re: Altenator?
« Reply #4 on: 26 June 2006, 11:56 »
Got some help from an electrical retailers who sold me a new reg. with new bushes for a tenner.
Told me to check earth strap and bridge +ive and -ive terminals on the alt. to check if the wiring to the battery light on the dash had corroded a bit. When I did this got 13.5V on idle. Turns out the connector to the dash clocks was loose - not telling the regulator to kick in.
The bloke even took the regulator back!!!!
All in all a good result :D
Mk2 8v and 16v.
