Author Topic: leaky leaky  (Read 2133 times)
Offline dibdub
leaky leaky
« on: 13 December 2003, 18:32 »
my mk2 16v is costing me a fortune on parts leaking!it failed the mot this week on a leaky drive shaft gaiter,a leaky load sensing valve and a feul leak at the feul pump area. :'( :'( :'(
a mate had a look at the feul leak 2day and found a small hair line crack in the feul pump housing which it is leaking out of!!!while finding this he also noticed a oil leak >:(.he seems to think it may be a rocker cover gasket problem,because oil seems to have got everyway! is this a cheap fix?what  a nightmare!
bad luck or what!rest of car seems to be mint(bodywork,engine etc)so its worth getting done,but what a kick in the teeth right near xmas when money is even tighter.
Dinky
Re:leaky leaky
« Reply #1 on: 13 December 2003, 20:02 »
Ur not having much luck like r u?!Can't really advise but the rest of the forum will,i just hope u stick with it n get it sorted! :)
Hope theres no more leaks after this one! ;)
Dinky :-*
Blue MK2
Re:leaky leaky
« Reply #2 on: 13 December 2003, 20:12 »
The rocker cover gasket is cheap and easy to do. I was told its about ?3 from VW. Im having a rocker cover gasket leak too its nothing serious.
Blue MK2
Re:leaky leaky
« Reply #3 on: 13 December 2003, 20:15 »
actualy in your case it is serious :P
Offline Helios_Blue_Valver
Re:leaky leaky
« Reply #4 on: 13 December 2003, 21:10 »
16v rocker cover is a little more involved than an 8v but still not too bad. Just follow the book and you will be fine. :)
Offline dibdub
Re:leaky leaky
« Reply #5 on: 14 December 2003, 15:56 »
by the book i guess ur talking bout haynes?where bout in there is it cant see it must be blind! :o
