Author Topic: Flashing Light  (Read 1310 times)
Offline Blandy
Flashing Light
« on: 14 June 2006, 11:42 »
Hellp guys needs some advice.
Just had my car mot'ed which it passed when they changed the brake hoses. car drove home fine. Turn the car on this morning and the red temp light was flashing and not stopping all the way to work. cant didnt seem any different or over heat or anything. do u know wats going on? would the mot man have touched anything to make it have a problem?
Cheers for all ur help again
Blandy
'91 Mk2 Golf GTi 16v
'06 Golf Gti
'05 Astra Sport SRI
1995 Toyota Starlet Turbo
Offline Neaty
Re: Flashing Light
« Reply #1 on: 14 June 2006, 11:46 »
check your water level, mine did this this morning actually. it flashes when it gets too low.
Re: Flashing Light
« Reply #2 on: 15 June 2006, 17:55 »
If that checks out, unplug the level sender plug and bridge the wires.  If that fixes it then replace the level sender :)
Offline Dizzie
  • Make friends with your fast
Re: Flashing Light
« Reply #3 on: 15 June 2006, 23:38 »
which is the plug on the header tank :D
Offline Blandy
Re: Flashing Light
« Reply #4 on: 26 June 2006, 07:49 »
soz guys wat do u mean buy bridge the wires???
'06 Golf Gti
'05 Astra Sport SRI
Re: Flashing Light
« Reply #5 on: 26 June 2006, 08:14 »
disconnect the level sender plug, then run a piece of wire between the plug terminals :)
