Author Topic: THE INFAMOUS WINDOW PROBLEM - HELP  (Read 2920 times)
Offline JAKESANGEL
« on: 14 June 2006, 09:32 »
Help, my passenger window (electric) goes down no problem but coming up is very slow and sometimes just stops altogether. It wont go up automatically either, I have to keep my finger on the switch. When the window is down if i bang on the outside of the door there appears to be a slight rattle sound as well. I have read various comments on the website about "clips", does my symptoms sound familiar or can anyone give me any help or advice. If it is the "clips" I have a mate who can replace them but any idea how much the part(s) will cost.  cheers guys
Offline topher
  • Administrator
  • fully functioning
Re: THE INFAMOUS WINDOW PROBLEM - HELP
« Reply #1 on: 14 June 2006, 09:47 »
If your clips had snapped your window would be rattling around in the bottom of your door mate. The motor is possibly on its way out. Also this is the time of year when tree sap, pollen and road dust all like to mix up on your glass and make it harder to push the window past the rubbers. Give the glass and rubbers a bloody good clean to see if it helps... but its more likely the motor.
Offline JAKESANGEL
« Reply #2 on: 14 June 2006, 10:11 »
Cheers mate appreciate it, so if the clips had broken does that mean the window would'nt come up at all ?
cos my still comes up and its level (not at any funny angle) so the motor might be the answer. Cheers
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 14 June 2006, 10:20 »
Yeah the motor still works when the clips snap, but the window falls into the door and won't come back up again. I fixed my drivers side one on Saturday, the new metal clips look chunky enough to last a while.
Re: the motor.. I'm not sure if they can be cleaned up or serviced in any way, but they're a doddle to replace.
Offline welshgar
« Reply #4 on: 14 June 2006, 21:44 »
the window doesnt always drop if the clips have broken... it happened to me on the way home from BVF on the weekend, window went up very slowly (with a clunk)...
i stripped it down and the one plastic clip had sheered and the other had a crack in it !!
window finally closed, but very slowly.
you can get the whole inner skin with runners on for around £70 from the stealers, its easier to change altogether rather than just the clips.
old one
new one fitted
the motor might be knackered but you'll only tell if you open it all up (its not that bad really)...
hope this helps a bit  :undecided:
Mk4 GT TDi::RS4's::weitec coilies::RCCR::polo mirrors::cream leather::
MK1 1.5 GL Auto restoration....coming along slowly :-(
its not the winning that gives me pleasure....its the taking apart
Offline Flipmode
« Reply #5 on: 15 June 2006, 15:31 »
only slightly related here.....but my rear passenger side window has been knackered for 10months plus. Luckily it stoppd in the fully closed position but then wouldn't move at all, i could hear a click when pressing the controls, but no movement whatsoever. Anyway the other day i pressed the buton by mistake and it worked, it now moves up and down fully on demand, completely fixed. The good lord really does work in mysterious ways !!  :smiley:
Offline welshgar
« Reply #6 on: 15 June 2006, 17:04 »
LOL, miracles really do happen  :grin:
do you know what caused it to stick????
Offline Flipmode
« Reply #7 on: 15 June 2006, 19:06 »
no idea mate, hardly have any passengers in the back so certainly wasn't over use, guessing some kind of loose connection thats fallen back into place??    :smug:
Offline welshgar
« Reply #8 on: 15 June 2006, 19:37 »
well at least its working now for the summer  :grin:
Offline JAKESANGEL
« Reply #9 on: 16 June 2006, 10:40 »
CHERRS FOR ALL THE ADVICE, IF IT AINT THE MOTOR IM JUST GONNA REPLACE THE WHOLE LOT AS WELSHGAR SUGGESTED. I KNOW ITS A STUPID QUESTION BUT WHEN I BUY THE WHOLE INNER SKIN WITH THE RUNNERS ARE THE CLIPS STILL GOING TO BE PLASTIC OR ARE THEY THE NEW METAL ONES
